Friday
My phone is Samsung s22 Ultra. My current subscription will change at the end of June with the new subscribed plan.
yesterday
As one of your suggestions, a simple restart of my cellphone (turning it off and on again) solved the problem. Thank you all for trying to help.
yesterday
Thank you for your help, hairbag1 and hTideGnow, I’ll try your suggestions and get back to you with the results.
Friday
hi @TuanTran1
you might have turn on Mobile data limit, disable it
about check to make sure you disable Power Saver and Data Saver modes
Friday
The Mobile Data button was greyed out when I tried to check my data usage. At home, I accessed my Public Mobile account online using my desktop and found that I still have plenty of data (I stay home all the time).
I will try your suggestions. I hope they will help. Thanks.
Friday
log in to your account and see if you still have data available ? Also, you could try re-boot of your cell. And you can also do a network re-set to see if anything helps.
Friday
I had just left home and was about 1 km away, heading to do some shopping in a Toronto neighbourhood when it happened. The Wi-fi button was fine but the Mobile Data button turned gray.
Thank you for your info.
Friday - last edited Friday
if you're travels are throughout Manitoba...you're gonna might need a newer cellphone. Here's some thing to read with a device checker at the end of the article..
https://www.publicmobile.ca/en/get-help/articles/volte
Also, make sure that VoLTE is enabled in settings.
