04-07-2024
07:51 AM
04-07-2024
04:16 PM
computergeek541
Good morning,
Hoping i can get some guidance with this issue. I have set up my pixel 8 Friday night and had everything port from fido to PM using the same phone number i had prior. I recieved confirmation email and call from fido to say everything has been cancelled and transferred to PM. Everything works great, such a as phone calls incoming/outgoing and data. If i can get some help or direction on what my next steps are, id truly appreciate it !
04-09-2024 01:21 PM
Yes, i was able to get everything resolved
04-09-2024 12:50 PM
Has anyone gotten back to you yet?
04-07-2024 07:42 PM
Im glad that it is working for you as well ! Thnx everyone 😊
04-07-2024 04:30 PM
Thx for all your help. I'm now resolved as well.
04-07-2024 11:17 AM
I did the comment button at the bottom right side of the screen
04-07-2024 11:10 AM
Thx. Sure wish they would get back to me.
Glad to hear your issue was resolved.
04-07-2024 11:07 AM
I started with chatting to the bot, and then it came up with a spot to put in a request for an agent, they then messaged me and were able to fix it.
04-07-2024 11:00 AM
How did you get the CS Agent?
04-07-2024 10:58 AM
I was able to get on with a CS Agent and I am all good now
04-07-2024 10:11 AM
not yet
04-07-2024 10:09 AM
Any luck with the text issue?
04-07-2024 10:00 AM - edited 04-07-2024 10:00 AM
@Pippi19 - I have sent the porting team number to your community inbox: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
If they don't help please contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
04-07-2024
09:19 AM
04-07-2024
10:16 AM
Dunkman
844-xxx-xxxx
Good luck as they couldn't help me. Told me the porting request has gone through and I need to re submit a help request on the community form.
04-07-2024 09:15 AM
I am having the same issue, would you be able to send me the porting team number as well please @Handy1
04-07-2024 08:40 AM
@Bonafidebee Yes sent !
04-07-2024 08:39 AM
i am not seeing the three dots
04-07-2024 08:38 AM
Would you by any chance be able to send me this number as well please
04-07-2024 08:36 AM - edited 04-07-2024 08:37 AM
@Pammer_Sue I will private message you the porting team number . They can give status update on the port or re trigger it if needed
04-07-2024 08:30 AM
Thx for the reply.
Unfortunately, your suggestions didn't work for me. No difference. I was still not able to send or receive text messages .
Also as an additional FYI...
I could send and receive text messages when I reinserted my old Bell Mobility SIM. But was not able to call or use data. It makes me think the porting isn't fully complete and I need Public Mobile to reinitiate the porting process again. Also, my Bell Mobility account says the account is closed.
04-07-2024 08:15 AM
try adjusting Chat messages options.
Worst case, just turn off RCS messaging to see if you're texting in & out functions.
04-07-2024 08:09 AM
This is so frustrating because so far im loving everything about the service, except for this one flaw lol. I can definitely keep you updated if i figure anything out.
04-07-2024 08:07 AM
Not much help but I'm experiencing the same issue on my setup on a Samsung S20 Ultra from Bell to Public Mobile. I started my transfer Saturday morning and still no difference today. I'm hoping this gets resolved soon. If you have any luck please let me know and I'll do the same.
