06-04-2017 09:40 PM - edited 01-04-2022 01:50 PM
06-05-2017 02:24 AM
Long distance add-ons are useless without a voice plan. Those add-ons only cover the long distsance portion of the call, and since you won't have a voice plan at all, you can't call out to anywhere.
06-04-2017 10:26 PM
06-04-2017 10:22 PM
you could also check out fido 15$/month 2gb data ( if still available) and use voip like fongo.com
06-04-2017 10:01 PM - edited 06-04-2017 10:05 PM
As the name implies, the add-on is a complementary feature to a base plan. So you can't add-on long distance when the base plan has no calling. All plans come with a number even if it doesn't have calling or text.
