No service
Natapita77
I can not make a call or receive call when somebody calls me it goes directly to voice mail. It has been 2 days since i switched the company
Natapita77
Hello Mayor i did forget to reply yes to the old carrier for service transfer. So what should i do next
@Natapita77
When you switched over to PM, did you pick a new number or port your old number over from another carrier?
If you ported over, did you confirm to the text with YES with the old SIM in your phone? You have 90 minutes to reply or porting will be cancelled.
HI@Natapita77    there are others with the same voice problem  Look like something issue
Try restart the phone once.
and Please submit a ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
