No service
Alex69
I have had my plan for a long time 3 plans and last month they removed 3 payments this month they only removed one payment . Now my fathers phone doesn't work . I added 40 dollars to my account but still don't see my wife's phone or my father's only mine......
11 REPLIES 11
@Alex69 wrote:
Yes orignaly open in store , now all stores don't offer the service ....
No they don't. And the previous system had an account creation method. Now it doesn't.
So contact support. Then while you wait for them to sort all that out, buy vouchers from recharge.com and dial 611 on your phone to reactivate your service. Then dial the toll free number and use another voucher to reactivate your fathers service. Then your wifes. Or if one of the accounts is working then dial the toll free from that phone.
That way the services would be working and you can take your time with support to get the accounts all set up.
@Alex69 wrote:
All 3 have been on my one my account and the same credit card . How can my father get his to work again . If I'm not able to on my end
Hi @Alex69   just open a ticket with CS agent.  I had the steps written above
CountyDownIeUk
Are you on Public Mobile?? You need an account for each phone number and a separate login for each account all with different email addresses.
Alex69
Alex69
Alex69
All 3 on the same credit card , I can see the phones for reactivate.
CountyDownIeUk
Are all 3 accounts on the same credit card? Has credit card expired?
removed = I interpret meaning taking a payment and removing funds from your auto pay set up.
@Alex69   are you using different My Account login for the 3 accounts?  If not, then you might see if you have write down the login for the other two
If you don't have them, open ticket with CS agent and they will set them up for you
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
dust2dust
Did you sign up those other accounts in a store? If so, did you ever create the login account for them?
If you know your 4 digit account pin then you can dial 611 and make payments. Or from any phone dial 1-855-4pu-blic. Or buy vouchers and use 611 (no pin). Or use real time payments in some stores.
Outdoorsman
@Alex69 hi you need separate emails for each plan sounds like you may not, you need the help of a cs agent to sort it all out for you
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
      https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user
will13am
@Alex69 , not sure what you mean by they removed payments?  Are you able to go into the self serve accounts and manage the payments?  If there is funding in the account and it is not self renewing you should be able to manually reactivate the account.  I suggest accessing the self serve accounts using incognito mode.
