No service
Juruthir
Please assist as no service for a week now
CSA_PM
Customer Support Agent
Thanks for escalating! The client is already in contact with an agent.
HI@Juruthir
Service was working before?  you have no voice and data?   What phone do you have? where are you at?
Try Reboot the phone and Reset network settings.  Also, test the sim card on another phone
if same, you will need further help from PM support agent.
, you can submit  ticket by direct message:
slusagm
did you check your My Account and confirm the account is active or not suspended because of payment problem
also, you tried the sim on another phone?   If you did all that, then ask PM to check.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
