Referral
BLhome
Forgot to add referral code?
CSA_PM
Customer Support Agent
Thanks for escalating! The client is already in contact with an agent.
HI @BLhome
still not late, PM support agent can add it back for you
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
PM would be able to help to add it back.  So, you are the one who just joined?  you just need to open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.)  Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
