03-16-2024 10:02 PM
I received my sim today, Installed it around 6 pm March 16, it ported my number no problem , however i have no internet and when i make a call i usually get a message saying sorry we cannot complete your call , because it seems you don't have a active plan on your account.
I checked the APN setting and they are perfect.
03-17-2024 09:59 AM
A Cs agent contacted me and repaired the problem with the account. Thanks to everyone who tried to help!
03-17-2024 07:39 AM
@N1tr0 Part of your problem with Forbidden AI might now be related to the scheduled maintenance outage
03-17-2024 06:22 AM
so I get the Forbidden A1 when logging in on the browser , if I use the app it tries to log in and boots me out right away back to the login screen, I tried force close, clearing the cache and data , still doesnt work, also still no reply from my support tickets
03-17-2024 01:00 AM - edited 03-17-2024 01:01 AM
@hTideGnow wrote:HI @N1tr0
usually that mean account not setup properly
But you can give it one more try by using Incognito/Private/Secret mode on the browser, but I suspect it won't work and you need support to fix both things
I 'm not sure that there's a link between the forbidden AI message and icnorrect account set ups. I see this error message on a regular bassi, and it's usually fixable by either force closing or clear the app storage before trying to log in again.
03-16-2024 10:35 PM
your right , it doesn't work, i have to wait for support , thanks
03-16-2024 10:32 PM
HI @N1tr0
03-16-2024 10:31 PM
Any idea when i try to login it shows me a new page that says Forbidden A1?
03-16-2024 10:21 PM
I just sent a direct message, thanks
03-16-2024 10:19 PM
HI @N1tr0
if putting in on another phone still does not work, you realy need agent's help to check the setup on the system. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-16-2024 10:13 PM
i did try it in another phone , and it also did not work. Im not sure if the app completed the sign up, it gave me 2 check marks , one for the porting of the number and the other ( im not sure)
if i try to login it say forbidden A1
03-16-2024 10:09 PM
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-16-2024 10:06 PM - edited 03-16-2024 10:08 PM
Have you rebooted your phone after you installed your card? Have you tried your SIM card in another phone?
I had a situation a week or so back setting up my neighbors. Thanks to advice here, I took out the SIM card, placed into another phone, rebooted the phone and I had service. Then re inserted it back into the phone they were to use. Bingo! They were both up and running. I had to do it to both phones oddly enough.
Just to also confirm, you signed up using the Public Mobile app? Was able to finish the sign up?
