06-11-2018 09:31 AM - edited 01-05-2022 04:54 AM
Hi i bought new sim and plan yesterday .but when put it in its showing no network and when i dial number then its says not registered on network . Pls help
06-12-2018 11:54 AM
@Rdasm wrote:@Tajinderplease check your phone's IMEI if its compatible with PM in the cehck your phone section here (https://www.publicmobile.ca/en/on/get-started). Once confirmed, check if your plan is activated by logging in (https://selfserve.publicmobile.ca/). Usually it takes around 10-15 mins for a plan to be activated. Reboot your phone just in case. Contact a moderator if you have checked all the above.
Hope this helps
@Rdasm @Tajinder unfortunately, the IMEI checker on Public Mobile's site isn't very accurate for compatibility. You should still use it to verify your phone hasn't been blacklisted (reported as lost/stolen), but for compatbility, you should check on https://www.willmyphonework.net.
06-11-2018 06:13 PM
Hope this helps
06-11-2018 06:10 PM
Hey there Tajinder, if you're still having technical issues please open a private message with us and we'll help you out!
06-11-2018 06:06 PM
06-11-2018 05:18 PM
@Tajinder please note that @LEGO and @GreatCanadian have nailed the two most likely issues:
1) Your phone may not be compatible with Public Mobile. If you post the brand and model (please be as specific as possible with the model number), we can help check.
2) Your phone may be locked to another network. If you bought it from a carrier other than Telus or Koodo, and prior to Dec 2017, it is almost certainly locked to that network and needs to be carrier unlocked to use with Public Mobile. You will need to contact that original provider and ask them for an unlock code.
06-11-2018 01:21 PM
Is the phone unlocked?
GC
06-11-2018 12:44 PM
06-11-2018 11:30 AM
Its used
06-11-2018 10:27 AM
I recommend you send a private message to the moderator team and ask them to investigate that issue for you. include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
How long until a moderator replies?:
How can I view my private messages between myself and a Community Moderator?
06-11-2018 09:59 AM
@Tajinder what phone are you using? Is it new, a used phone? Can you try your sim in a different phone and a different sim in your phone. This isolates account vs hardware issues.
06-11-2018 09:42 AM
@Tajinder, did you check your network settings? Is your network set to automatic? Can you see Public Mobile / Telus as an available network that you can select?
06-11-2018 09:34 AM
I did so many time
06-11-2018 09:33 AM - edited 06-11-2018 09:33 AM
You can try powering off your phone and taking out the SIM and re-inserting it.
