04-18-2026 08:58 AM
My husbands cell phone isn’t working so I am contacting you from mine. He has no network showing on the sim card
04-18-2026 10:48 AM
04-18-2026 10:45 AM
No service and now account has been locked
04-18-2026 10:34 AM
you don't say if you both have the same cellphones...what cell does he use ? Does hubby still have data and messages working ? If so could be a VoLTE issue. Here's something to read with a device checker at the end of the article.
04-18-2026 09:01 AM
hi @Bstg
so, your phone is working and just not your husband?
where you are at and what phone the husband is using?
did you check the My Account and is the account status active? or suspended/ on hold?
on the husband phone, try Reboot the phone and then reset network settings
if same, test your husband's sim card on your phone
last, ask PM support agent to check. Submit a ticket with CS Agent on your husband account using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, submit ticket by direct message using husband's community account:
Remember CS_agent will reply to the Community inbox within 2 to 4 hours, please check inbox here:
