No network connection
StephRobers
I have gone through the trouble shooting tips and reset network settings as the chat bot suggested. Still in SOS mode. This happens frequently. What can I do? Is this something that is often a problem with Public because I may have to switch carriers if that’s common. I can’t be without my phone on a regular basis.
2 REPLIES 2
hi @StephRobers
what phone do you have? the service ever work?  did you try testing your sim card on  another phone?
Check with PM support agent, they can refresh your account.
 submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
is that new account?
are you using eSIM? if you are, you can try buying a new one
or ask PM to reprovision your account
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
