No mobile data
rdgdawg
I tried resetting the networks settings, set the APN and the data still is not working. I have an LG G7 One.
9 REPLIES 9
@rdgdawg Also check if your Data Usage is enabled.
RosieR
Hi @rdgdawg please read this article Public Mobile APN settings for LG G7 One
I hope it helps
RosieR
rdgdawg
Call and texting work, so I'm thinking you're right and I might have to do a factory reset.
@rdgdawg Are you having any issue with calling or texting services? If only data is having an issue, likely APN settings would be the problem. A lot of LG models require factory reset when carrier is switched. Make sure to back up all your data if you go this route.
@rdgdawg wrote:
I just switched over to Public and my account shows I have 1GB remaining
Try taking sim outta the phone for a moment, then reinstalling. Sometimes that gets things percolating.
rdgdawg
JK8
@rdgdawg
Log into self service and look under My Data & Add-Ons. Confirm that you have data listed. If not it has been used up.
@rdgdawg ,
  • ensure Data is enabled
  • try going into airplane mode for a few minutes, then go back to regular mode
hairbag1
Is it possible you've run outta regular plan data until next renewal ? If so, you can get one of the data add-ons.
1 GB Data add-on...$15
200 MB Data add-on...$5
