No data
Dartmango
When it asks you to sign into network public mobile does that mean I used my data up?
edited by computergeek541:  miscategorized - changed from "community" to "service"
Dartmango
Data is back.  I paid my bill and boom back in service. No more having games use my data!!!
@Dartmango  - if you have data left showing on your overview section of your self serve account, then try:
  • turn your phone, remove and reinsert your SIM card, turn your phone back on
  • toggle into airplane mode then back again
  • perform a Reset of your Device's Network settings
Not sure if this is similar to what you are seeing, but that message appears in this site:
https://support.honeywellaidc.com/s/article/Android-device-is-showing-Sign-in-to-network-notificatio...
JL9
What plan do you have?
@Dartmango  Yes, it does sound like you used up the data
Login to My Account, check the My Data & Add-on section, see if you see a line about data like the following:
if you don't see a similar line that like, your data for  current cycle are all used up
