No data
Travel2
I am currently in Mexico and if I’m not connected to Wi-Fi, I have no data
2 REPLIES 2
@Travel2
make sure Roaming data is turned on
Change the network connection to Manual and manually connect try each of these 3 networks AT&T, Movistar or Telcel
hairbag1
@Travel2
If you have the Canada / us / Mexico plan ? ...make sure to enable Roaming in the settings of your cell. You'll automatically connect to the better of AT&T, Telcel or Movistar.
