No data
Mohammed21
I still have data but it doesn't work. I fixed the PIN as in the website. I tried reach out the support but uselessly
@Mohammed21
Try resetting the Network Settings on your phone. It happens a lot on my previous carrier but ended resetting the network for it to work.
Mohammed21
Yes voice calls work perfectly, I tried all these but didn't work. The problem is that it was working before and suddenly it just stopped and kept giving errors messages
@Mohammed21
voice calls work??
do you have another phone to test the sim card??
Also, try changing the network mode, tllest them all, 5G 4G and 3G
and if it is an Android, make sure you didn't have any data limiter enabled
