02-02-2024
02:50 PM
02-02-2024
06:28 PM
computergeek541
I see this has been asked in the past and the response was more or less "You snooze, you lose" 😞
I helped a friend switch to Public Mobile and needed to get her existing number swapped to the Public Mobile SIM. At the time I didn't have my referral code available, so I pushed through and thankfully everything went smoothly.
Is there a way now to add a referral code post-activation?
Would really be nice is that was an option (one-time is fine) for the new user...
02-02-2024 03:07 PM
Thanks for the quick reply, and the working link for a private message to the CSA 🙂
PM FTW!
02-02-2024 03:00 PM
Not true. If you activated without referral code (forgot to enter) contact agent to do that for you. At least it worked few years ago when I signed up and forgot to enter ref. code.
If opening a ticket does not work very first time, contact agent directly: send a private message to the CSA - agent by clicking (Ctrl+) Here
