05-01-2025
03:40 PM
05-02-2025
05:58 AM
computergeek541
05-02-2025 01:21 PM
hi @Super-Data
try Reset Network Settings on your phone. And check you didn't enable any data limit
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
05-02-2025 01:19 PM
Having this same issue and restarting my device didn’t do anything. I’ve also tried turning airplane mode on/off but no luck.
05-01-2025 03:48 PM
When this happened to me I had to restart my phone for data to work. It was weird.
