Data renewal
Viny1
How can I get more data?
2 REPLIES 2
@Viny1
If you have enough Rewards points. You can redeem for additional data. Login to your account and go to Rewards-Browse Catalogue and scroll down to the amount of data you need. 5 points for 5gb, 10 points for 10gb and 15 points for 15gb. Data will expire after 30 days.
hi @Viny1
you can either buy data addon or message PM support and ask for early renewal
