05-15-2026 08:45 AM
Tried resetting networks. Restarted phone. Turned phone off for a minute and turned back on. Turned on airplane mode and turned it off after 10 seconds. Still not working. Not sure how long as I dont usually phone people.
05-15-2026 11:32 AM - edited 05-15-2026 11:33 AM
Unfortunately, all carriers will shutdown 3G in the future and you need a Samsung S22 or newer for it to be VoLTE compatible.
https://productioncommunity.publicmobile.ca/t5/The-Lounge/VoLTE-compatible-phones/td-p/1434185
05-15-2026 10:15 AM
It is a Samsung S20. I entered the imei number in the link you provided and says it is not compatible. I guess I can't use Public Mobile anymore. Thanks for your help.
05-15-2026 09:07 AM
What is the make and model of your phone?
Your phone requires VoLTE to make and receive calls with the 3G shutdown.
Here is more information on VoLTE:
https://www.publicmobile.ca/en/get-help/articles/volte
Enter the IMEI if your phone to see if it is VoLTE compatible.
