No Service
10-03-2021 10:29 AM - edited 01-06-2022 03:41 AM
Hi - I'm a Public Mobile customer and I have no service. My account is paid up by my husband, who is the main account holder. My account # is 1000000xxxxxxxxx
His phone works, but mine says "no service".
Edit by Dunkman: removed personal information
Phones
10-03-2021 10:15 PM - edited 10-03-2021 10:17 PM
Login to your account and check the Transaction History.
If you don't see any payment there corresponding to your plan cost, and there is no Available Funds either, your payment has not gone through.
Try making a manual payment (plan cost or a little extra) and check if there is a Reactivate button to click on.
If after that the account still shows suspended, try to Suspend then Resume service to reactivate the account (via Plan & Add-ons > Lost/Stolen Phone)
10-03-2021 10:06 PM - edited 10-03-2021 10:07 PM
@Ahs you said you paid already, do you see any Amount showing as Available Fund on you My Account? If so, does that equal to the plan amount you paid? If so, go to Manual pay and pay $1 more. Then check if Reactivate current plan button is there and click on it. Then logoff My Account and reboot your phone.
If Available Fund = $0, then you might not have paid anything yet. Try to pay your Plan Amount +$1 extra. Then click Reactivate current plan, then logoff and reboot your phone.
Let us know how it goes
10-03-2021 10:03 PM
I have been trying to contact staff member but no luck. Auto pay. Customer, credit card was expired, on line registered new CC and paid, but still no service. What to do?
10-03-2021 12:22 PM
@LeslieRan wrote:Hi - I'm a Public Mobile customer and I have no service. My account is paid up by my husband, who is the main account holder. My account # is 1000000xxxxxxxxx
Just to make sure...check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
10-03-2021 11:41 AM
You should can also double check that your sim card number matches what public mobile has in the system. If not you should change password and contract PM ASAP.
To check, go on my account and click on the option "change sim" the last 4 number listed in the system should match your sim card. In case your sim is defective, you can change it there as well.
10-03-2021 11:28 AM
What is the account status? Does it say 'Active'?
If yes probably simple reboot (turn phone off/on or even Airplane mode on/off) might resolve this issue. If it is Not Active, then further analysis are required as suggested above (autopay failure, not sufficient funds, etc.)
10-03-2021 11:27 AM
@LeslieRan did you meant his phone works with his own SIM or it works when you put your SIM into his phone? If you have not try that yet, put yours into his phone and see what is it showing.
Also, you have tried to login to My Account and check the account status as I mentioned earlier?
10-03-2021 11:22 AM - edited 10-03-2021 11:34 AM
If your account is not suspended, Have you tried your SIM card in your husband's phone?
If it doesn't work either, your SIM might be defective.
If it works, put it back in your phone and try these tips:
- Restart Your Device.
- Toggle Airplane Mode.
- Manually Select Network Operators.
- Reset Network Settings.
10-03-2021 10:38 AM
you might want to remove your personal info. This is an open forum and you don't want them posted here. Simply go back to your post, click on the 3 dots and click Edit.
So, when you login to My Account, can you confirm the status is Active?
If is is showing suspended, can you confirm when was the last successful payment date? Was it over 30 days ago?
If so, maybe Autopay failed? Try to manually pay the Plan amount and see if it goes through. If still fails, try to pay Plan Amount +$1 extra
Once payment goes through successfully, click Reactivate current plan, then logoff My Account and reboot the phone.
10-03-2021 10:35 AM
And here too please and thank you.
10-03-2021 10:32 AM - edited 10-03-2021 10:33 AM
Please edit out your sensitive info this is a public forum.
Your services are needed here and elsewhere! thx
Edit:
Can you log into your self serve account?
10-03-2021 10:25 AM - edited 10-03-2021 10:26 AM
@LeslieRan you might want to remove your personal info. This is an open forum and you don't want them posted here. Simply go back to your post, click on the 3 dots and click Edit.
10-03-2021
10:23 AM
10-03-2021
10:47 AM
Dunkman
Hi Jade - I'm a Public Mobile customer, and my account is paid up, but I have no service. How do I get service restored?
My account number is
1000000xxxxxxxxx
Many thanks,
Leslie xxxxxx
