No Service
akoszorek
I have done everything, including Reset Network Settings and I still can't get service.
11 REPLIES 11
akoszorek
This evening I will
@akoszorek
Do you have access to someone else's SIM card to test in your phone? That will eliminate or point to your phone as the issue.
akoszorek
I have switched Airplane on & off several times, also does not help.
@akoszorek wrote:
Account is active & payment is up to date. I still have to try the sim card in another phone. Account has been active for 3 years, went down yesterday. I am not technical at all and am so frustrated.
@akoszorek
Does toggling into airplane mode and back again get you back on the network?
If your device is not listed at blacklisted on the site @Anonymous provided, then check if the last 4-digits on your SIM match the same 4 digits listed on your Self Serve account under "Change Sim Card" option.
If the numbers match - GREAT!
If the numbers DO NOT match, then someone has been fraudulent on your account. Submit a ticket to CSA to report this and list your phone into lost/stolen status.
Methods to contact CSA here:
https://www.publicmobile.ca/en/bc/get-help/articles/contact-a-moderator
 @akoszorek : Maybe you can try devicecheck.ca
@akoszorek
your account 4 digit pin, when you Activated online you don't remember, don't worry about it
told them to the change it for you,
akoszorek
My PIN????? which PIN
akoszorek
@akoszorek
can you try test your SIM card in another device to you test is wrong with SIM or your device, and if SIM card you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Only one way to solve your issue , explanation to Customer Support Agent by CS_Agent,
and the are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here to get started.
  • or you can send a private message to Customer Service by CS_Agent, by Click Here.
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Service by CS_Agent, will Response by private message to you inbox
         Good Luck
 @akoszorek : Did you try the SIM in another phone? Check that your account says Active? Have you just recently activated?
JK8
Are you a new customer? Is your phone unlocked?
