03-07-2021 03:00 PM - edited 01-06-2022 02:15 AM
I have had no service on iPhone 8 for few days.. restarted phone and also checked SIM card with no luck.
03-07-2021 05:07 PM
It is not that weak. Now I am waiting for pm to change back the phone number to my own and they are not responding. They changed my SIM card back to mine but not the phone number
03-07-2021 04:52 PM - edited 03-07-2021 05:01 PM
Click on Plan Details under your self serve account. It's also under your Plans and Add ons tab.
It'll be listed in one of the first or second lines in there.
03-07-2021 04:50 PM
My pm account was hacked and they changed my SIM card number and cell number. Pm changed my SIM card back to mine, but cell number is still not mine. Where can I find my cell number on my account.
03-07-2021 04:44 PM - edited 03-07-2021 04:45 PM
@Salowe I really wonder how that happens. Did you use some 'weak' password? (if you don't mind answering that). Cause it can be for either they got your password somehow or they convinced PM that they are you.. If it is the second option, that is really scary then.
Thanks.
03-07-2021 04:40 PM
Thanks. Someone hacked my public mobile acctandchangedmy phone number
03-07-2021 04:39 PM
Thank you. Someone got into my public mobile account and changed my phone number
03-07-2021 04:35 PM
@Salowe I think there are a few things mentioned that you would need to look into to rule out. I believe that one of the best options in your case would be to try the sim in another and of course it would have to be compatible on the PM network. You will know that if it works on the other phone then there is something wrong with your iphone or its settings.
03-07-2021 04:27 PM
@Salowe wrote:I have had no service on iPhone 8 for few days.. restarted phone and also checked SIM card with no luck.
@Salowe ,
If your SIM number matches your SELF SERVE account and your SELF SERVE says "ACTIVE" status, try your SIM card in another compatible PM phone.
If the SIM works, your phone have an issue.
If the SIM does not work, clean the contact points of the SIM then try again. If does not work, maybe a dead SIM.
Then check with the Moderators about your account by either method @HALIMACS provided. If Moderators deem your account okay, pick up a new SIM and swap it on your SELF SERVE account.
Good Luck!
03-07-2021 03:03 PM
Is your account status active or suspended? Did you check the last 4 digits of your SIM card from the self service account to match your phone's SIM card? rule out SIM swap fraud.
https://productioncommunity.publicmobile.ca/t5/Announcements/SIM-Swap-Fraud/m-p/650969
03-07-2021 03:03 PM - edited 03-07-2021 03:05 PM
Hi @Salowe
In your self service account, choose Change Sim Card.
Ensure the last 4 digits on the self-serve SIM number match your SIM card to ensure you have not been sim jacked.
If they do not match, while still on the self-serve account, put your phone in lost/stolen mode and change the password. Then check and secure all your financials.
From, there, contact a moderator, there are 2 methods:
If that's all good, try this troubleshooter: (you can ignore #4, already done above...)
