No Service
10-07-2019 01:35 PM - edited 01-05-2022 09:25 AM
Me and my wife are experiencing "No service." Both of our accounts are in good standing. What's the problem?
Service
10-07-2019 03:00 PM - edited 10-07-2019 03:32 PM
@smp99 wrote:
@Lowufo wrote:I am in Kamloops and have not experienced any outages
I'm sure there is more than one tower in Kamloops. It could be a single tower.
Yes of course there is more than one tower in Kamloops 🙂
But I have not experienced any issues will driving around town. So it must be isolated to one tower or one area of town.
10-07-2019 02:58 PM
10-07-2019 02:45 PM
10-07-2019 02:24 PM
As discussed in the other thread, yes, the OP is in Kamloops.
https://outage.report/ca/public-mobile
@Alan_K see this thread and other thread regarding a possible outage in parts of BC.
10-07-2019 02:10 PM
Are you in BC by chance? Someone else reported no service here: https://productioncommunity.publicmobile.ca/t5/Self-Serve/No-Service-in-Kamloops/m-p/436115
10-07-2019 02:06 PM
Probably unlikely where both devices are showing the symptom, but try removing and reseating both SIM cards? Check the SIM slot for dust and debris while you're at it.
10-07-2019 02:04 PM
@lefuglyduck wrote:Yes, we have already rebooted our phones. As far as we can tell there is no service outage.
Well give us a hint as to which area in Canada you are ? We can see if there's any reported outages in your location for you.
10-07-2019 01:48 PM
Afternoon,
You can also check this web site for reports of network outages.
https://istheservicedowncanada.com/status/telus
10-07-2019 01:46 PM
@lefuglyduck if both your phones are doing it I would say it's a tower outage, I'm sure if you check around you'll find more people with the same problem if that's the case
10-07-2019 01:44 PM
10-07-2019 01:38 PM
@lefuglyduck, it is possible that there is a local network outage in your area. Try rebooting the phone to see if it will reconnect to the network.
10-07-2019 01:38 PM - edited 10-07-2019 01:38 PM
If you login, what is your status?
How long has it been?
Are you at the same location?
