03-14-2019 10:33 PM - edited 01-05-2022 03:43 AM
I activated my account and now my phone says "No service" my phone is unlocked. Help!
03-14-2019 11:53 PM - edited 03-14-2019 11:53 PM
@kierra5163 wrote:I ported my number. I am using a phone from telus with my old sim card in it currently
Keep using old sim if it still works. Public sim shouldn't say no service even if port not done. Probably need to contact moderator_team.
03-14-2019 11:17 PM
@kierra5163 just to confirm your pm sim when inserted says no service? and your selfserve account says active?
I ask because the PM sim should atleast work for outgoing calls, once activated failed port or not.
can you try the sim in a different phone? try a manual network search?
03-14-2019 10:56 PM
Thank you so much!
03-14-2019 10:55 PM - edited 03-14-2019 10:56 PM
@kierra5163Yes, as long as it keeps working then the number is still registered to Telus. Once it stops working you can switch it for your Public Mobile SIM.
03-14-2019 10:54 PM
Do I leave in my old SIM card in for the mean time?
03-14-2019 10:53 PM
@kierra5163If your PM SIM doesn't start to work within a few hours of activation you may have a failed port, if you do then you will need to contact a moderator, you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
03-14-2019 10:52 PM
Yes, It says "Active"
03-14-2019 10:51 PM
03-14-2019 10:50 PM
@kierra5163 wrote:I never cancelled my other sim card. Am i supposed too?
No please do not cancel the old service. If you do that, you will no longer be eligible to port the number. We know one thing, your port has failed which is why the old service is still working. I have a feeling the account set up on this end has faltered also which does correlate to no service. Are you able to login to the self serve account to see what the status is?
03-14-2019 10:48 PM
The line with the other carrier will be cancelled automatically when the port occurs. You shouldn't cancel the other line, and in fact it needs to be a working line for the port to occur.
03-14-2019 10:48 PM - edited 03-14-2019 10:49 PM
@kierra5163 wrote:I activated my account and now my phone says "No service" my phone is unlocked. Help!
Did you port your number from other provider to PM?
If yes, is your old SIM card still working?
If no, login to your PM self-serve account. Is you account status active?
If yes, put the PM SIM card into different phone if you have access to another phone.
Which phone are you using?
A phone which supports only GSM signal will not work with PM.
03-14-2019 10:48 PM
03-14-2019 10:46 PM
03-14-2019 10:45 PM
03-14-2019 10:44 PM
my old sim card still works
03-14-2019 10:43 PM
03-14-2019 10:43 PM
Yes it says active and yes it recognizes that it is in there
03-14-2019 10:39 PM
I have restarted a few times! I moved my phone number
03-14-2019 10:38 PM
@kierra5163, does your online account show active status with the proper plan features? Is your phone able to recognize that there is a SIM card inserted?
03-14-2019 10:36 PM
