9 hours ago
9 hours ago
@GillianGlasgow wrote:Yes I did everything in the directions. I said YES. Transfer was successful now I can't receive calls.
You're going to need help from Customer Support...use this link to start the process...
9 hours ago
I also try deleting esim and bought a new one still not able to receive calls.
9 hours ago
9 hours ago - last edited 9 hours ago
more info would be nice. Did you recently activate your new Public Mobile account successfully ? Did you attempt to port your old number to your new PM acct or did you take a new number ? Did you reply YES to the sms you rec'd about the port request ?
