02-02-2026 10:46 AM
Will be arriving in Puerto Vallarta next week and wondering the same thing. If you've arrived, have you had any issues?
02-02-2026 11:24 AM
assuming you have a Canada / Mexico calling plan !! If not, you won't have Public Mobile service as soon as you leave Canada, and Public Mobile doesn't offer any add-ons for Mex. Make sure you have a plan that works in Mexico.
02-02-2026 11:19 AM
Thanks so much. Very reassuring 🙂
02-02-2026 10:54 AM - edited 02-02-2026 10:57 AM
I've been in Mx for a month now. Public Mobile works great here. You'll connect automatically to the better of AT&T, Telcel or Movistar. To dial most any Cdn number from your cell, dial thusly 001 ...area code... number.
No pasa nada, amigo
sp
02-02-2026 10:48 AM
hi @BeaNich
it will work. Make sure you turn on Roaming Mobile Data on the phone.
You might still get a text asking you to buy roaming, you can ignore the text
and make sure the phone connected to either AT&T or Telcel. If not, change the network connection to Manual and try connect to both manually
