No Service
BigJ
It's been over 5 hrs since I joined Public Mobile and transferred my number over, I still don't have service. I cannot talk to anyone and the service with the previous provider is canceled. Can anyone help?
2 REPLIES 2
Socrates8567
What you can try is to go into your settings on your phone and reset your network settings and then reboot your phone. That may help. Just make sure you have your pm sim card in the phone when you reboot.
@BigJ
look like the sim card or account wsan't provisioned properly.  No worries, easy fix for PM support, you just need to engage them by direct message
Private message CS Agent at:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
