No Service Again!
pistolpete_1981
Hello,
My phone has no service again! I just topped up my phone a week or so ago using a prepaid card. Can someone help me please. I need my phone tomorrow for business!
@pistolpete_1981
Check to see if there are any outages in your area:
https://istheservicedowncanada.com/status/telus/map
hi @pistolpete_1981 login  my account and confirm if account still active
if it is? reboot the phone and test.  Click Reset All Networks and test
put sim in another phone and test
pistolpete_1981
No I cannot log into my account again. says Unauthorized access / Accès non autorisé
I got in touch with them Thank you!
Ranabbb
Public is under telus, if you have no telus towers near your area then signal is going to be hit or miss, drive to somewhere local and if it's working there then signal at your house is probably just bad.
If it's not working at all then open a ticket with an agent and they'll answer you. You'd get a notification on your account when you log in if your plan wasn't active
Is the account active @pistolpete_1981  can you log into confirm ? But you can reach out to support to investigate
send  a  private message   To CS_Agents
