12-27-2023 02:08 PM
The subject says it all - trying to port my old number from Cityphone Telecommunications to my new PM. I have my Cityphone sim still in the phone, but now my service is "SOS" and I never received the porting request text.
Should I be phoning my old provider? Thanks!
12-27-2023 02:36 PM
@DJ-C-Hendy Great! One or two other providers don't send the porting request text. I wasn't sure about Cityfone but since that sim had stopped working it seemed likely that the port had completed. Welcome!
12-27-2023 02:31 PM
@DJ-C-Hendy We happy to hear it welcome to public mobile and happy new year 🥳
12-27-2023 02:30 PM
I did just that and things seem to work fine in both sending and receiving texts/calls. Thanks very much. Seems like I did not need to give approval to my old provider afterall.
12-27-2023 02:12 PM - edited 12-27-2023 02:31 PM
@DJ-C-Hendy Try the PM SIM card in the phone do you have services ? If same (sos) you will need to contact support to re provision the sim for you
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
12-27-2023 02:09 PM
@DJ-C-Hendy Have you tried the PM sim in your phone and restarted it?
