No Network Connection
lost_explorer
My phone is connected to Public Mobile, but it says "no connection."
I've tried restarting my phone, and resetting the network connections, but no luck.
I can't text, make phone calls, or use data.
10 REPLIES 10
lost_explorer
Telus is now reporting that they have identified a failure in their network affecting southeastern Manitoba.
"The cause of the issue has been identified, and equipment to support repair efforts are being sourced. There is currently no estimated time of restoration."
Nir01
I am here in Steinbach MB and from this morning I have also experienced no network in phone for Public Mobile.
summonerson
Also in South Manitoba here, and I am experiencing notably low signal strength and sometimes complete outage.
greengardener
DownDetector.ca is showing show issues in the Telus family ATM but nothing like last evening's problem.I've been OK in central-eastern ON all morning. Big Red and Big Blue situation is much worse this noon hour.
lost_explorer
Thanks for pointing that out. I'm in southern Manitoba, so no outages are listed for that region. At least, not yet.
@lost_explorer wrote:
I've been a customer for several months. A friend of mine, who's also with public mobile, is experiencing the same issues.
Sounds like a genuine local outage.  There was a data outage reported yesterday.  I am not seeing any issues in the GTA at the moment.
Sansan
There was some sort of usage yesterday.  Perhaps still ongoing...
HI @lost_explorer
which area you are in?
check Telus outage : https://www.telus.com/en/ab/outages
lost_explorer
hairbag1
@lost_explorer
are you a new PM customer...did you attempt to port your number from previous network ? Can you try that sim in a different cellphone ?
