04-22-2020 05:31 PM - edited 01-05-2022 10:29 AM
Hey guys, I have been having a problem with my incoming calls.
I can send and receive texts, make calls but 3/4 I can't receive incoming calls. it's being an issue for a few months now, and btw this is not a number I transfers from an other operator!!
There's no way to get help or call to anyone help please ....
05-03-2020 01:27 AM - edited 05-03-2020 01:28 AM
Try putting it in airplane mode for 5 min. Then take it off of airplane mode. This will completely disconnect you from the network and then re-establish a new connection to the network. (Hopefully a much better one!)
05-03-2020 01:09 AM
@Elie02 have you tried resetting your network settings? or manually choosing the pm network?
05-03-2020 12:59 AM
I am currently using an iPhone X, didn't have this issue before with my other operator, same phone.
05-03-2020 12:57 AM
This is an issue that's been happening long before covid, but unfortunately didn't get to fixed it. now that everything is close. I've been noticed it more.
05-03-2020 12:56 AM
Unfortunately didn't touch anything regarding my setting. like I said 3 pout 4 times call are not coming through.
05-03-2020 12:55 AM
Im connected, no problem there. 3G works with no problem also. it's still happening
04-22-2020 07:20 PM - edited 04-22-2020 07:30 PM
@Elie02 if you haven't restarted your phone in a long time, you can try that. phones are computers nowadays, so software can easily interfere with things. if it continues to happen, it could be a network/cellphone tower issue in your area. Covid-19 is overloading the networks... that could easily be the problem. you said 3 out of 4 calls you can't recieved, correct?
04-22-2020 06:53 PM
@Elie02 What type of phone do you have? Make sure to check your privacy and filtering settings to ensure you haven't turned on the setting to only accept calls from your contacts.
04-22-2020 05:39 PM
04-22-2020 05:34 PM
@Elie02 Hi is it possible that you turned on your do not disturb on your phone by accident?
04-22-2020 05:33 PM - edited 04-22-2020 05:34 PM
How is your reception when you force 3g only connection?
Can you try it on another phone?
If it's not hardware related you should contact moderators https://publicmobile.ca.ada.support/chat/
