No Incoming and Out going Voice Calls
DansGrill
Is there an issue with Public Mobile voice network? I am not able to make any voice call and no incoming calls for days now. Data (internet usage) is sometimes works, sometimes not in the last couple of weeks. I did verified my phone bill is paid up to date. Thanks
2 REPLIES 2
dabr
@DansGrill    You could try putting your SIM in another compatible phone to rule out any device issues.
Perhaps also try a network reset by tapping Settings>General Management/System>Reset>Reset Network Settings.  You'll need to re-enter your WIFI password after doing the above.
However, if this has been going on for several days now, I'd ask customer support to take a look at your account.  Here's couple of links to either submit a ticket (preferred option) via chatbot or send private message to CS_Agent:
chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@DansGrill
Check to see if there is an outage or repairs in your area:
https://istheservicedowncanada.com/status/telus/map
