02-17-2023 09:18 AM - last edited on 02-17-2023 10:04 AM by computergeek541
02-17-2023 12:59 PM
@Sunlight what I did is to delete ALL the messages including the deleted ones. You have an option in the Public mobile voicemail. Another time because the first thing didn’t work I disabled the option to have badges for voicemail in my parameters. I closed my phone and opened it again and enabled the option again.
02-17-2023 11:21 AM
Try to perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before. This could help with finicky things on your device, including voicemail issues.
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
02-17-2023 11:11 AM
Click on the little icon in the upper right of my post and a menu should pop out and select not solution.
02-17-2023 11:10 AM
I did both of them but it did not work
02-17-2023 11:10 AM
it didn't work for me
02-17-2023 11:09 AM
no
02-17-2023 10:47 AM
Did you recently transfer a number in?
02-17-2023 10:43 AM
02-17-2023 10:43 AM
02-17-2023 09:46 AM
I had the same, recurring, notification on a non- PM iPhone device.
I went into the phone app settings and fiddled with the notifications, and it seems to have disappeared.
02-17-2023 09:27 AM
@Sunlight is this a badge notification (the red dot or with a number there)?
If so, presse and hold the phone or message icon until a content menu comes, then click Clear badge
you can also try to clear phone app cache and message app cache and reboot the phone
