New plan?
Feedo90
Hello everyone,
I found this plan listed as an option in my account but I'm not sure if it is a 3 months plan with 9 GB included for all the period or each month as there is no mention that it is a 3 months or 1 month plan, also no mention for how the data is allocated.
Anybody here have tried this plan?
hi @GRR
the 9Gb is for 90 days or ask PM support
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
GRR
So can anyone clarify if it's 9gb per 30 days or 90 days?   I know it's a 90 day plan for 57$ for the 90 days.  I'm interested in it if it's 27gb per 90 days.  Now I'm on a 60gb 75$ 90 day plan but never use more than 10gb per 3 month
Meow
It says there: 90-days
It will be very expensive if it is 1 month for $57/9GB
hairbag1
@Feedo90
looks like its a 90 day plan.
added...Poorly described though.
9GB's data to use in 90 days. If you don't use it all, you lose any unused data. You'll start over every 90 days with a new batch of 9GB data.
