New plan not working
MyraLivingston
Just switched to public mobile yesterday with new SIM card. Still have no service almost a day later. How long should I have to wait until I have service? My plan says ‘active’ so I’m not sure if there is anything else I should do.
jlynneconrad
I also just recently switch to Public Mobile. I ported my old number and following the directions, was able to connect instantly. I would attempt to restart the phone a couple of times, and then contact customer support to make sure everything was set up correctly!
Nika
Hello!
I found when I first switched I had to restart my device a couple of times before it connected to the new network.
darlicious
@MyraLivingston
If you have no services at all working on your pm Sim card then it did not provision correctly upon activation.  You need to contact customer support to fix that for you. You can submit a support ticket via SIMon or send a private message. Put "Sim card not provisioned correctly  upon activation" in the subject line and leave a detailed message. Read the spoiler in the following post if you choose the private message option.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Get-Support-Contact-Customer-Support/td-p...
will13am
@MyraLivingston , if your activation was successful and your account is showing active, the service should be working right away.  By chance, did you include a number port as well and did you confirm the port on the old service?
