03-06-2017 05:11 PM - edited 01-04-2022 01:34 PM
I haven't used my phone for few days after ending of my previous plan so my line got deactivated.
today I changed to a new plan to reactivate but I couldn't make a phone call or send/receive text messages. All the time I make a call it says "I don't have enough addon", but I have unlimited province wide in my plan.
PLEASE HELP
03-07-2017 02:38 PM
You're most welcome 🙂
03-07-2017 02:35 PM
@Mary_M wrote:Good morning @Rebel-Star
thank you for raising concern with us regarding your plan change!
This sounds like the plan change didn't stick, which caused somewhat of a "failed renewal". Despite this, I was able to easily fix it for you and this should not happen again. Simply power cycle your device and enjoy 🙂
I hope this helps,
Mary
Thanks @Mary_M for sorting out the issue.
03-07-2017 11:15 AM
That is very strange, I can see both posts :!
I'll move this post to make is more clear!
Thank you 🙂 TheOldVR
Mary
03-07-2017 11:10 AM
Hey @Mary_M.
Something is funky here... I've looked this thread with my iPad and my desktop.
The original post I see is below:
I have a Samsung Galaxy II that got in a bad state.
I am trying to use an unlocked ZTE V889S ( http://www.dx.com/p/zte-v889s-android-4-1-wcdma-bar-phone-w-4-0-capacitive-screen-wi-fi-gps-and-dual... ) It properly sees the SIM card but still no network access.
Is there anything I can do? I do not need data, just voice.
Thanks,
The topic is: "ZTE V889S does not get network access" by hamel. Your response is for the topic of "Re: New plan not activated" directed at Rebel-Star who is not mentioned in the thread that I see.
I'm not sure if this appears the same way for others... but it looks like two threads have crossed paths causing a mid-thread topic change when I look at them. (maybe not for others).
I can send a screenshot if it helps.... (not trying to make extra work though, this just seems odd)
03-07-2017 11:02 AM
Nope, it's in the right place! The plan change didn't kick in causing the services to remain suspended - this is a known glitch.
03-07-2017 10:57 AM
I hope this helps,
Mary
Ummm... is this post in the wrong place or did I miss something?
03-07-2017 09:55 AM - edited 03-07-2017 09:55 AM
I hope this helps,
Mary
03-06-2017 07:54 PM
While you are waiting for a moderator, login to your account and see if says "Active" or "Suspended". If Suspended do you see Available Funds equal to the plan you want; if yes, just click Change Plan, activate now, then logout and reboot your phone. In all other situations, await the moderators.
While service is down you can make phone calls with an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
Hang in there; it will get sorted.
03-06-2017 06:36 PM
Yes, 9PM EST (Toronto/Montreal timezone).
@Rebel-Star if you're not sure how to contact a moderator via private message, please see the two links at the bottom of this reply for more info.
03-06-2017 05:47 PM
I believe MODS are available until 9:00 p.m. Monday to Thursday. Send PM as previously stated for help.
03-06-2017 05:28 PM
@CaNuCk07 wrote:Very odd, if you recewived a confirmation text.
Best thing to do is send a private message to the moderators with all your account infor and the issue. Unforuntaetly they are gona for the day, they'll start back up at 9am tomorrow morning.
Sorry but I didn't receive a confirmation text from PM about my new plan active
03-06-2017 05:26 PM
03-06-2017 05:19 PM - edited 03-06-2017 05:20 PM
@CaNuCk07 wrote:@Rebel-Star Did your payment go thrugh properly?
When you added your new plan did you ensure you added vo
Yes my payment went through properly, I got the confirmation
03-06-2017 05:18 PM
