11-07-2024 04:31 PM
Can I just use the SIM card from my old phone and put it in the new phone
11-15-2024 05:13 PM
Thanks
11-07-2024 04:33 PM - edited 11-07-2024 04:35 PM
@Lyle_2 Yes absolutely that’s the beauty of having physical SIM card instead of eSIM
adding and if the SIM card appears to big for new phone just snap off the outer edge and it will work @Lyle_2
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
11-07-2024 04:33 PM
HI @Lyle_2
yes, you can. This is the nice thing of sim card
in case your sim card is too big for your new phone, check it, you can peel the outside and make it smaller
11-07-2024 04:32 PM
@Lyle_2 Yes you can, nothing to worry about.
