08-20-2022 08:41 PM
I moved to a new phone ( umidigi f3) set everything up the same as it was on old phone ( umidigi F1 play), but cannot connect to the internet using these settings.
Can anyone help?
Thanks
08-21-2022 11:54 AM
Hi there
I have solved the issue and now have a good data connection.
Thanks to all of you who responded 😊😊
08-20-2022 09:31 PM
How about, do you have data left on your account? Plan and/or add-ons?
Images of what your current settings are would be helpful though.
08-20-2022 09:23 PM
I understand you checked the APN settings, but check this full list, this is the longer one.. or maybe post your full APN settings here as well. Pay attention to space, extra space or comma here and there couple screw it up too
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type:GID
MVNO value: 4D4F
08-20-2022 09:08 PM
Yeah I've done all that several times. Still not getting access
08-20-2022 09:07 PM
All APN settings are correct. Still cannot get access
08-20-2022 08:55 PM
@howard0178 Hi check your apn settings The APN (Access Point Name) settings contain information that's needed to make data connections through your phone. For most devices, you are not required to configure the APN settings. However, if you are experiencing data issues, check whether your APN is properly set up by following the steps below.
Next, check your APN settings:1) Open your settings, then tap:
2) Ensure the following fields match:
3) If you needed to make a change, hit save, reboot, and you’re good to go! Make sure to enable data in your phone settings.
Need
08-20-2022 08:52 PM - edited 08-20-2022 08:54 PM
The phone is compatible with PM.
Check the APN settings:
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
