10-31-2021 03:50 PM - edited 01-06-2022 03:55 AM
10-31-2021 08:06 PM
Existing SIM will work in any unlocked phone as long as it can 'fit' into SIM slot.
If you currently have nano SIM and new phone will take nano that is simple switch. Otherwise let us know what size SIM do you currently have and what new phone will take and guys will advise (as they already did) how to use existing SIM in new phone.
10-31-2021 06:40 PM - edited 10-31-2021 06:40 PM
I have SIM adapters (nano noosy) if any one needs. PM me.
You should be able to use old SIM and save the new SIM for an emergency replacement or for a referral.
10-31-2021 05:52 PM
If you ordered a "new" phone from pm it will come with a new sim card. Save the sim card for a friend or if you ever need to replace your current one. But if needed you could use the housing from the new sim card to make it larger if need be....unlikely but it's there if you need it.
10-31-2021 04:00 PM
is too easy take out the adapter off your old SIM card and use on your new phone...
10-31-2021 03:55 PM
Yes you can.
Just make sure the appropriate adapter is being used (or not), depending on the SIM tray size of the new device.
10-31-2021 03:54 PM
@Kered13 this is the removable housing @dabr meant
even you need a new one, it's around $5.99 to $10 from different stores .. just do no order from PM online as it might take long for delivery . If you really need a new SIM, you need to follow this to request SIM change:
SIM Swap Fraud: 2 factor-authentication - Community (publicmobile.ca)
10-31-2021 03:52 PM
10-31-2021 03:51 PM
depends on what kind of SIM you have on the old one
the new phone are usually nano-SIM
what model you have?
