New phone number
Keimj
Hi is there a way to get a new phone number never used before vs a recycled/ re used number
thanks
2 REPLIES 2
gblackma
No, there is no way to know if a number is new @Keimj , choose a new area code and a number higher up on the spectrum. However, the newer area codes also come with their own problems. They may not have been added to every data list in the country. Stay safe.
thanks
Sure. If you go in and start looking you'll probably get a bunch of new area code/prefixes for whatever new area code/prefixes might be in your area. Popular kinds of numbers or easy to remember or traditional area code/prefixes will be gone or recycled.
