New add credit card
Sangha720
Hi I  forgot my login id & password
i want  add new credit card  my phone last 10 days to suspend please help
647-xxx-xxxx suspended
email@gmail.com
Edit:  Personal information redacted by will13am.  Please do not post personal information in the public forum.
GinYVR
@Sangha720 Without the web interface access you can still add funds to your phone by purchasing a voucher at any corner store to get your phone working. Moderators might take up to 48 hours to get back to you.
selva1
As others said, send a quick email to moderator team and they are generally quick in responding to questions. Good luck.
duffer900
xxxxxxxxxx suspended
You may want to remove the personal info in your post by editing it...
Moderators can assist getting in to your account
you can contact the Moderator_Team here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Triguy
You should remove your personal information.  When you setup your account, you should have received an activation email with your details.  If you still need assistance then contact a moderator.
Moderator can be reached at
will13am
@Sangha720, you will need to contact the moderator team for support.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
