New activation
10-09-2019 03:20 PM - edited 01-05-2022 07:29 AM
I currently have a Samsung Galaxy S9+ that I purchased outright on a Bell plan. What do I need to do to activate it with Public?
Phones
10-10-2019 01:21 AM
I'm pretty sure all phones bought in Canada come factory unlocked this days. All you need is to buy a PM sim card and activate it on line or just go to Walmart/ wow mobile and have them doing it all for you.
Good luck!
10-10-2019 12:58 AM - edited 10-10-2019 01:25 AM
@fdv7221 wrote:I currently have a Samsung Galaxy S9+ that I purchased outright on a Bell plan. What do I need to do to activate it with Public?
It wouldn't be bad idea to check if phone is locked but shouldn't be needed. It's supposed be unlocked when you leave the store. I don't think Samsung does self locking any longer with newer models.
10-09-2019 06:06 PM
In addition to all of above, get a referral code from a PM subscriber and use the code during activation to get a $10 referral credit.
10-09-2019 03:53 PM
The absolute easiest way to do this is by going to a wireless provider depot at the mall or you will have to order or buy a sim card and activate it yourself.
10-09-2019 03:29 PM - edited 10-09-2019 03:31 PM
@fdv7221 I am a satisfied, 4+ years, PM customer but a curmudgeon and so recommend reading: https://productioncommunity.publicmobile.ca/t5/Getting-Started/BE-PREPARED/m-p/112014#M20827
10-09-2019 03:29 PM
You can purchase a PM sim either online or through a retailer. You will need to register the sim and select a plan.
10-09-2019 03:26 PM - edited 10-09-2019 03:28 PM
@fdv7221 to unlock a Samsung they'll give you a long unlock code that when you put the public mobile Sim card in the phone the first time it will ask you for it! You can get it from bell or Samsung.ca
10-09-2019 03:23 PM - edited 10-09-2019 03:26 PM
You'll need a new PM SIM and your email. You can click this link to see the process: https://activate.publicmobile.ca/
Edit: the above link would be needed when you start the activation process, but use @geopublic link to get started.
10-09-2019 03:22 PM
