New acctivation
Tamermakar
Hi, I had transfer my line since 6 days from another company to Public mobile and I still have a problem for receive calls and messages
Is that normal to stay all those days for finish the transfer?
Thanks a lot
7 REPLIES 7
Alex799
sent ticket today
@Alex799 Tty the sim on another phone trick if you have a 2nd phone around
if still not works or you don't have another one, open ticket with PM
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
Alex799
TRIED THAT STILL GOES DIRECT TO VM
@Alex799- Did you try to transfer your old number in? Did you leave your old sim in to confirm the transfer? Does your old service still work?
@Alex799 for voice receiving problem, try to change your preferred network to 3G Only or WCDMA Only
  If you have  another phone around, try to put your PM SIM there.  That can confirm it is not a device problem as well as trigger a sim re-provision and it could resolve your issue
Alex799
IM HAVE SAME ISSUE TEXT IN & OUT WORKS BUT WONT RECEIVE CALLS GOES DIRECTLY TO VOICE MAIL NO RING ON THE PHONE ?? WHAT TO DO ??
@Tamermakar
Is the number coming from a VOIP or landland company? Those transfers take longer. If the number is coming from a cellular carrier,  porting has failed.  Most likely the account information provide was incorrect.  You can try again by going to https://publicmobile.ca/chatbot
and then typing "port request".
