08-06-2019 09:07 AM - edited 01-05-2022 06:17 AM
When you switch to a new plan when does it kick in? I'm travelling to US tomorrow, and am considering switching to new plan (60$) to include the US Data and roaming...
BUT - does it kick in the next billing cycle, or is it immediately activated... I already have the 40$ plan, and want to go to 60$ plan, just want to make sure it activates right away, otherwise I'll just add the 250MB of US data to my plan...
Anyone know for sure when a plan change happens, if it's immediately, or next billing cycle?
Thanks!
08-06-2019 09:01 PM
Just a piece of advice... As you might know T-mobile could be very flaky and internet may not work even with ”LTE” showing on the phone. ATT is much better in this respect, so select them as a carrier (most of the time).
have a good trip!
08-06-2019 05:20 PM
@costanza if you travel to the US fairly frequently, it might make sense to switch to the $60 plan. If you're less frequent however, it's probably still more advantageous to keep your $40 plan (assuming it meets your needs other than roaming) and use the roaming add-on(s) as needed.
08-06-2019 09:18 AM - edited 08-06-2019 09:20 AM
@costanza wrote:When you switch to a new plan when does it kick in? I'm travelling to US tomorrow, and am considering switching to new plan (60$) to include the US Data and roaming...
Thanks!
Hi, you get to decide.
More info here: https://www.publicmobile.ca/en/bc/get-help/articles/change-your-plan
Keep in mind that if you pick change immmediately, you will lose whatever is remaining on your $40 plan.
Also if you want to change plans after your trip, you'll have to pick from the list of available plans at that time.
Have a good trip!
