01-23-2020 09:01 PM - edited 01-05-2022 09:09 AM
Is there a way to choose the last 4 digits of the phone number ?
01-23-2020 09:41 PM
01-23-2020 09:27 PM
01-23-2020 09:25 PM
@AMM wrote:Do I need to be in a specific browser to see this link?
Which link?
01-23-2020 09:25 PM
01-23-2020 09:23 PM - edited 01-23-2020 09:24 PM
@popping it was always during the signup, when changing it was never possible
well at least for last 16 months
01-23-2020 09:22 PM - edited 01-23-2020 11:59 PM
Hi,
You can Select the local no and then it gives you option to choose last 4 digit. If its available you can have it.
01-23-2020 09:11 PM - edited 01-23-2020 09:16 PM
@popping wrote:
@AMM wrote:Is there a way to choose the last 4 digits of the phone number ?
Yes. After PM server showed you a list of available numbers, there is link that you can select to supply the last 4 digits number
I was able to search the last digits number about 1 month ago. But I cannot get it again. The interface may be changed.
It may be the "search last 4 digits interface" will show up after select one number. I don't have a play account any more and I don't want to give up my 20 years old number.
01-23-2020 09:09 PM
When you sign up, not when you change
I don't know if moderators can help
Call the number to see if it was assigned and try
01-23-2020 09:05 PM - edited 01-23-2020 09:06 PM
You can change your phone number via self serve account. Once every 30 days.
Check the numbers.
I don't believe there is away to select last 4 digits yourself but you can open a ticket for moderators to inform you.
EDIT post - as @popping said on above post you can select 4 digits.
Good info to know thank you @popping
01-23-2020 09:03 PM
