Network
foot
Can't receive or make calls on phone also Can't connect to network
13 REPLIES 13
@foot   would be nice if you can test the phone in another area and check if it is a local network issue
If you are unable to go around and test, open ticket with PM support using Chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@foot  Then I suggest using the link in my last post to have support investigate for you
foot
account is active
foot
still nothing i think it is there problem on there end
@foot  after trying @will13am @and @softech   suggestion , if all else fails you can ask support to investigate
  • Get support by starting a conversation with virtual Chat box /SIMon. Click here
  • you can send a private message   To CS_Agents by clicking here.
  Watch for reply top of page to the
   Right ( envelope image )
@foot you are an existing customer since 2020?
do you have another phone to test the sim card?
Also, try to change the preferred network to 3G and see if it connects the 3G network
foot
Done that
will13am
@foot , does the phone show that there is a SIM card in the phone but there is no network connection?  Have you checked the self serve account to make sure it is in active status?  Has there been a recent software update that might have affected phone functionality.
@foot  Can you try SIM card in another device and see it services are working
Adding also if you sign into self serve is your account active or suspended
@foot  Also check
Outage   map in your area:
https://istheservicedowncanada.com/
foot
No
@foot  try to reboot device
@foot  Did you just activate a SIM card ?
