04-03-2022
07:13 PM
04-03-2022
11:59 PM
computergeek541
Someone please help i dont know the master code or the network unlock pin
04-03-2022 11:58 PM
You won't want to contact Public Mobile customer support agents about this. They will not be able to help you unless you're trying to insert another carrier's SIM card in the phone which would indicate that your phone is locked to Public/Telus. As you've said in the thread title that the phone is asking for a network unlock PIN, this is full confirmation that your phone is locked to a carrier.
04-03-2022 08:25 PM
HI @SweetMagicat if it is SIM Card PUK you need, you can use this direct link
04-03-2022 08:01 PM
Hi @SweetMagicat the only one that PM able to help is for SIM card PUK. If you have set a PIN on the SIM card, you need to enter the SIM PIN every time the phone is rebooted. If you entered too many wrong one, then it will be locked but PM Support can help
But if the PUK is for something else, then PM won't be able to help
04-03-2022 07:49 PM
What is the exact message shown on your phone? There are a few versions that mean different codes.
From a previous thread:
SIM network PIN blocked. Enter SIM network PUK."
- This is asking for Samsung's "master code" - I got this after entering the wrong code for the message below too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN"
- This is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you easy peasy. If you enter this incorrectly too many times, you'll get the error message above.
PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
04-03-2022 07:22 PM - edited 04-04-2022 12:28 AM
If you have a Samsung phone, it maybe locked by Samsung or a carrier and you need to contact Samsung Canada at 1-800-726-7864 or by the carrier listed on your phone under Cellular Network.
