Network service
07-19-2024 01:28 PM
I live in rural southern Alberta. My service is so bad that I have to walk out of my house and down the street to make phone calls. This has been happening for a few months. Who do I contact to solve this problem?
Service
07-19-2024 02:33 PM
@Darcie1 it's possible that there is an outage where you are. The map below will show you that information.
https://istheservicedowncanada.com/status/telus/map
You can contact a CS_agent from one of the links above to get more information
07-19-2024 02:29 PM
Very strange, i have seen them post about having outages and they are working on a fix, but i thought most was fixed or at least improved by now.
Have you tested this with another device? to rule out the possibility of it being a hardware issue with your phone.
07-19-2024 02:02 PM
The service was always good, so it's odd that the coverage would change.
07-19-2024 01:46 PM
@Darcie1 , you might want to look at this cell tower map which will give you more granularity than the coverage map. Bottom line is that if you are too far away from the nearest tower, coverage may be compromised. There is not much you can do.
07-19-2024 01:38 PM
@Darcie1 if you want to see what the TELUS coverage map in your area looks like here's some info:
07-19-2024 01:36 PM
@Darcie1 to contact a CS_agent click on the link below:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
