Network not working
patteoh
Hello, having the issue with no network access (exclamation over the network). Rebooted phone and checked account status, no issues.
@patteoh
Try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if calling/texting service work then.
Just to be sure, check that you your phone is not blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
@patteoh
Does it show Public on your phone?
You might want to check to see if there is a Telus outage in your area:
https://istheservicedowncanada.com/status/telus/map
Looks like a lot in BC, Alta and Ont.
darlicious
@patteoh
Can you still use your voice calling and SMS/MMS texting services? If so log into your self serve account and check for your plan data line. If you can't find it you have used up all your plan data for this 30 day cycle.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
dust2dust
Network as in no calls or texts? Or network as in internet data? Or just none of the above?
JK8
@patteoh
Try these:
Reboot
Reset Network settings
Reinstall sim card
Check self service to make sure you have data left under My Data & Add-Ons
Check your apn settings:
https://www.publicmobile.ca/en/bc/get-help/articles?q=Apn
Try your sim in another unlocked phone.
Edit: Could you clarify what you mean by “network”. Do you mean data not working or your phone not working at all?
