09-02-2022 11:17 PM - edited 09-02-2022 11:18 PM
I have been puzzled for the last two days - I seem not be able to access the rewards portal from Rogers/Fongo network, and I have no issue with access from Bell or Public Mobile.
The networks issue only affects rewards portal with zero issue with access to My Account and Community sites.
Very strange and puzzling. Trying different DNS servers other than Fongo's has no effect.
Has anyone experienced such issue?
09-18-2022 06:55 PM
Ah. Yeah static is very different from dynamic. I use eight dot eight dot eight dot eight for my DNS. There are also others that don't track and store. I think my second one is one of those. OpenDNS I think.
Yet you said at first that you had tried another DNS ??
But good with the update.
09-18-2022 05:18 PM - edited 09-18-2022 05:22 PM
@dust2dust I have technical a "static" IP from Fongo Internet - it stays the same even after two-days outage of Rogers Internet. Our area has an very unstable Rogers Internet connection (Rogers has not able to fix it for years and it is little wonder we had a huge scale outage), we could have no internet for several hours but Fongo would always assign the same IP after the service back online.
09-18-2022 05:09 PM
Update - it seems strange but appears to be an issue with Fongo Internet DNS servers. The problem solved after changing to CIRA's Canadian Shield DNS.
09-02-2022 11:50 PM
If you can login to the router then there is usually an option to renew the external ip which often picks up a new different one. If you have IoT devices then they might get confused.
09-02-2022 11:42 PM - edited 09-02-2022 11:42 PM
@dust2dust It is highly related to the IP. Just tried Opera with VPN on, it worked. Not easy to change a cable IP, will try later.
09-02-2022 11:35 PM
@softech Tried Firefox developer tools - can't find any error.
09-02-2022 11:35 PM
Cookies? Javascript? Refresh? Force change the router to a new external ip?
09-02-2022 11:35 PM
@tzliu , I am on Rogers cable internet, sometimes with VPN. I have no issues navigating any of the Public Mobile portals. I use chrome and firefox browsers. I don't have to resort to incognito mode which seems to be a good solution for many.
09-02-2022 11:30 PM
@dust2dust No VPN. Using PM's data works, switching back to WIFI, it is a blank screen. It must be network related - Chrome, Firefox, Opera, MS Edge, Safari all have the same problem.
09-02-2022 11:28 PM
@tzliu I guess you tried different browsers?
did you try to open the browser Developer Tools to see if it shows any error?
09-02-2022 11:25 PM
@softech just a blank/white page following the log-in. No issues with My Account and community sites. I am using Fongo internet which use Rogers' cable backbone. Don't have Rogers' wireless, no clue if it works.
09-02-2022 11:23 PM
Are you going through a VPN?
09-02-2022 11:20 PM
@tzliu but you can access the Self Sreve My Account on Rogers/Fongo network too?
what is the error? just cannot find the server?
and you tried on Rogers Mobile or just Rogers home internet?
